1983 Honda Accord PCV Valve and Hose
197,700 MILES • 4 CYL • FWD • MANUAL
MACY_MALONE
  • 9 POSTS
I have a 1983 Honda Accord. 5 speed manual, front wheel drive, 1.8L 4 cyl engine.
I can't seem to located the PCV valve and hose anywhere. I need to change the valve or at least check it but I can't find it.
Can you help please?
Apr 3, 2009 at 9:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
Your 1983 Honda Accord is not equipped with a Positive Crankcase Ventilation (PCV) valve.
Thanks for using 2CarPros.com!
Apr 3, 2009 at 1:08 PM
MACY_MALONE
  • 9 POSTS
That's what I thought because I know that they are usually located right off the valve cover.
So, my car runs fine but idles really irradically then stalls (usually after driving for a while).
When I kill the engine, the car makes an explosive "thunk" and a sucking sound comes from the engine right after (sounds like in the carb area).
Any ideas what to do?
Apr 3, 2009 at 1:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like you have a vacuum leak somewhere. Have you inspect all vacuum hoses and connections to make sure all is OK?
Apr 3, 2009 at 1:25 PM
