Howling sound with loss of acceleration?
128,000 MILES • AUTOMATIC
LARRY9ER
No check engine on, light howling sound when taking off from at a stop. Car doesn't have initial powerful go! Car goes to all speeds and moves from gears smoothly. When the car is in park, the car revs up normal. Was told may need to replace drive belt tensioner. Other than that, I can't figure it out. I have a machine, and no codes are on it.
Apr 3, 2025 at 7:22 AM
  • 55,694 POSTS
It sounds like the turbo can be going out but can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. It also could be a catalytic converter that has come apart or is partially clogged which can make a howling noise.
Apr 4, 2025 at 4:06 AM
LARRY JOHNSON4
This is the best I can do. It's not very loud outside of the car. And the camera barely picks it up when recording inside car. No smoke, no burning smells or any smells, no check engine, nothing leaking. The engine is not getting hot.
Apr 4, 2025 at 11:20 PM
  • 55,694 POSTS
Can you tell where the noise is coming from, front, rear, engine or transmission? Is the noise louder when you open the hood, will it make the noise when you are not moving, also do you have any warning light on? Sorry I could not tell much by the video.
Apr 5, 2025 at 4:44 AM
LARRY JOHNSON4
Noise is only when in drive and when I first start to go from a stop. It doesn't do for park or anything. I can rev in park and it is fine, no restrictions and no noise. Comes from the engine. Still no check engine light, no burning, no smells... again it is only when i first begin to drive from a stop whether it be at a light or whatnot. Yesterday i put my code reader on it and it came up with this which i know has something to do with turbo. I'm just hoping it is something small like a clog or it stuck.
P0299 pd 01/01
Apr 5, 2025 at 10:38 PM
  • 55,694 POSTS
Yep, the problem is the Turbo, sorry
P0299 – Turbocharger/Supercharger "A" Under boost Condition
So, I would remove the intake or exhaust side of the turbo and check the endplay to confirm. This guide can help:
https://www.2carpros.com/articles/how-turbo-chargers-work
Please go over this guide and get back to us.
Apr 6, 2025 at 6:11 AM
