Hi, my son was driving on the freeway and hit something that broke a hole in the oil pan around where the drain plug is. He got off the freeway with-in a mile or two and pulled over and the engine shut off. I got there within 20 minutes and the engine was still leaking and he says it didn't heat up or make noise before shutting off. we towed it home and dropped the pan and the oil smell normal and internally the engine looks clean. I tried just taping the starter to see if the engine would turn and it clicked but would not turn over.
I scanned it and I have:
P0011- Camshaft position actuator A Bank ! Timing over advanced
P2279 intake air system Leak
P0341 Camshaft Position Sensor A Bank 1 CKT Range /Perf
So I there a procedure that you could walk me through to try a restart? How to trouble shoot this?
I know it is an interference fit engine so do I need to check the timing belt first?
I have a new pan coming and I intend to do the work myself short of a timing belt, head repair or long block.
I have lots of experience but with older cars.
Thanks, your last answer was really useful!
May 9, 2020 at 8:46 AM
