2001 Holden Vectra Thud When Braking
SAMMY
Hi all, I was wondering if someone could help me out. I have a 2001 holden vectra equipe and it started making a kind of thud noise occasionaly when I apply the brakes and turn the steering wheel while driving. I can feel a bit of a clunk in the steering wheel and also in the brake pedal. Is my car falling apart or is it something minor that can be fixed???
Any help would be greatly appreciated.
Feb 7, 2006 at 2:57 PM
PEPPERMRJ
  • 1,158 POSTS
Have the front steering, suspension, and brakes checked immediately. You are not falling apart but do have a piece (ball joint, tie rod end, cv joint etc.)that is in serious need of repair.
Good luck and let us know.
Feb 10, 2006 at 5:27 AM
Suggested Repair
Have the front steering, suspension, and brakes inspected immediately. A worn part such as a ball joint, tie rod end, or CV joint likely needs repair.
Conversation Summary
The owner of a 2001 Holden Vectra Equipe reports an occasional thud when braking and turning, with a clunk felt in the steering wheel and brake pedal. The expert advises an immediate inspection of the front steering, suspension, and brakes, noting that a worn component such as a ball joint, tie rod end, or CV joint is likely in serious need of repair.
