2003 Holden Vectra Warning light
81,500 MILES • 6 CYL • FWD • AUTOMATIC
THOMASD1977
Have had warning light coming on (with spanner). have been told by an auto electrician that it is a fuel volume control regulator fault. My holden dealership hasn't heard of this error code. The light comes on constantly and intermittently, but the car seems to drive o.k. Any advice on this fault code would be greatly appreciated. Thanks.
Jul 21, 2009 at 3:27 PM
  • 31,937 POSTS
Hi there,
Go get a scan done and report the code here for further assistance,
Mark (mhpautos)
Jul 21, 2009 at 3:41 PM
LEE DEAR
Hello Thomas my 2003 Vectra has the same issue with the light coming on in the dash with the spanner, did you end up finding out what it means? Would be great to get an answer from you
Apr 11, 2011 at 5:02 AM
THOMASD1977
Hi Lee,
It's been awhile, but it was something to do with the cooling from memory, was a fairly cheap part to replace and fairly insignificant. Holden ended up diagnosing the problem and fixing it. It took about 3 visits and me getting rather irrate to finally get to that stage though. Good luck.
Apr 21, 2011 at 3:37 AM
SPRITE521
I also had this problem. After I use premium unleaded 98# twice, the problem had been solved. May be you can have a try, several guys have solve the problem successfully! Good luck!
Apr 27, 2011 at 6:15 AM
