1998 Holden Vectra Where do you check/fill transmission oil
1998 HOLDEN VECTRA
143,000 MILES • 4 CYL • 2WD • AUTOMATIC
JANSZOON
Its a CD Wagon.
Same as an Opel Vectra I think.
1) I cant easily see in the engine bay where you check or fill Transmission fluid. Or is this shared with the brakes or engine in this model?
2) Dash lights (speedo, RPM, Fuel gauge etc) and the heating/aircon backlights are out. Is there a central fuse for these lights or similar?
Cheers !
Aug 17, 2010 at 9:55 AM
DAVE H
  • 13,384 POSTS
yes there is a dashlights fuse in underdash fuse box .. transmission is a sealed trans and no servicing should be required
Aug 23, 2010 at 8:47 PM
