1998 Holden Vectra incurrect cam signal
245,000 MILES • 4 CYL • 2WD • AUTOMATIC
GARY DHILLON
i had checked with scaner code come up incorrect cam signl code 340 i had checked timing replaced cam sensor wiring replace sensor with new one engine waring lamp still on fault code still say incorrect cam shaft signal
Jul 23, 2010 at 8:24 PM
  • 31,937 POSTS
Hi there,
I have had this problem with a Vectra i have had at my work shop, still totally unresolved even after they spent a small fortune at the local Holden dealer, dealer and myself have both checked valve timing, sensor, loom, ECU... i am at this stage looking at a possible voltage feed back problem, but we are not totally convinced that this is the problem, i have known of others that have disposed of the car after not being able to resolve this same issue, i do think that this is just one of those problems that the dealers don't want to know about. I do know of one that was resolved with repairing a problem with the plug on the loom for the sensor, and ensure that the valve timing is correct as well.
mark (mhpautos)
Jul 23, 2010 at 8:51 PM
