1999 Holden Statesman indicator lights
134,940 MILES • 6 CYL • 2WD • AUTOMATIC
JOHNHOLDEN
I have 6 front panel indicator lights switching on sometimes when driving and sometimes at start up. Eventually they go out.
Power train
Air bag
ABS
Tract off
Battery
Oil
the Maintenance 120000 km then and 130000 km level panel indicator has not been reset.
Dec 19, 2009 at 1:31 PM
  • 31,937 POSTS
Hi there,
There is a fault with the ABS control module that can cause some weird dash displays, i would check with your local holden dealer to confirm this problem, the module is not cheap, if this is the problem, after market units are a lot cheaper and work just as well.
mark (mhpautos)
Dec 19, 2009 at 1:44 PM
