1992 Holden Statesman weak spark
20,000 MILES • V8 • 2WD • AUTOMATIC
PUD PALMER
engine cranks over, but wont start. has weak spark from coil (dull orange) have replaced coil, and changed ignition module with no change to spark. have also tried a new lead from coil. has new battery, rebuilt motor. was running when i drove into shed to put timing lite on it, then it stopped and now will not start.
Jun 23, 2009 at 5:41 PM
  • 75,988 POSTS
Weak ignition system
Measure the coil's positive terminal voltage.
Do this run a jumper wire from the battery positive post to the coil positive terminal -is it still dull orange-
Jun 23, 2009 at 6:19 PM
PUD PALMER
if voltage ta positive side of coil is low could that be caused by a power wire that is maybe resting against hot header pipe?
Jun 23, 2009 at 9:12 PM
  • 75,988 POSTS
Not familiar with this vehicle -The wire that's touching the header pipe is shorting out dunno if its your igniton wire to the coil fix it and see what happens
Jun 23, 2009 at 9:45 PM
