2003 Holden Rodeo warning light comes on
2003 HOLDEN RODEO
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAYCLOUT
The dash 'check transmission" light occasionally comes on in my rodeo.
When this happens the car goes into a "limp" mode where it only runs in low gear.
If I stop and turn the engine off then on, the light clears and the car drives normally.
The transmission had a service about 40,000k's ago, so I assume the oil is ok (no leaks visible).
Any ideas what might be going on, and is it safe to drive
Thanks
Mar 30, 2010 at 9:27 AM
RAYCLOUT
Update
I performed a scan of the OBD and no codes are showing.
Mar 31, 2010 at 11:59 AM
