2001 Holden Rodeo
SAVE
Engine Mechanical problem
2001 Holden Rodeo 4 cyl Four Wheel Drive Automatic
I have just change the battery but when I turn the key to start the engine, all the lights are on but the engine would not crank. I tried to jump start but still the same
Aug 7, 2010 at 12:43 PM
  • 31,937 POSTS
Hi there,
Ensure that all the battery terminals are clean and tight, check for 12V at the starter cable and 12V at the solenoid wire (small wire at starter) with key on crank, if yes starter will be faulty, if no check transmission isolator switch.
mark (mhpautos)
Aug 7, 2010 at 10:03 PM
