1998 Other Holden Models Car turns over but won't fire
1998 HOLDEN
260,000 MILES • 6 CYL • 2WD • MANUAL
STAFFY
We have a older Holden Rodeo, 3.2L V6 with approx. 260 000klms on the clock. Been running fine and was due for a service, partner filled the tank from empty with dirty fuel, black particles, and an not so clear looking fuel. Car drove 30klms fine, then spluttered and died. Logic said the fuel was the problem, so 2 weeks later and countless $$$$ the mechanic tells me he drained the system, injectors were cleaned, replace filters etc, had an auto electrician go over the car, checked the timing belt because one side is 175 compression, other is 100 so thought that might be a problem, that was fine, gone over the motor pretty much completely, its getting fuel but just will not fire, turns over with lots of effort just not going the extra stage. Mechanic has now pulled the rocker cover (prob not right term, still stuck with the old motors) off to check the camshaft etc and said that was all fine but said there was a fair bit of sludge in the motor, and we need a new motor or new car..... Any ideas, neither of the mechanics options sound terribly exciting to us, as the car ran perfectly until this tank of fuel.
Feb 26, 2009 at 8:20 PM
  • 75,988 POSTS
Do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 26, 2009 at 8:29 PM
STAFFY
Thanks, I will give it a go, though one would think between him and the auto electricians he sent it to they should've isolated a problem..... I just don't want to believe a car that ran great til dodgy fuel is now totally dead when it turns over great just won't fire... They did say there was power to the spark plus and injectors and they checked the CAS sensor so I can cross that off my list....
I should also add the Fuel injectors were cleaned two days ago at the auto electricians recommendation as they were pretty blocked.
Feb 26, 2009 at 9:07 PM
  • 75,988 POSTS
They out to make the easy money do what I've suggested and comeback with some results
Feb 26, 2009 at 9:35 PM
