1997 Other Holden Models won't chang into 2nd when cold
1997 HOLDEN
IANSAMP
Transmission problem
1997 Other Holden Models 4 cyl Two Wheel Drive Automatic
My Rodeo ute won't change up when cold it takes about 45 seconds and on and off accelerator before it will change into second and then 3rd gear. After a couple of minuits driving the gearbox works Ok??
Ian
Oct 16, 2009 at 8:45 PM
PGRTRUCK
  • 21 POSTS
Sounds to be the auto trans govenor valve. It requires replacing. You could try an auto service first but I doubt it will help
Dec 24, 2010 at 3:09 PM
