1984 Other Holden Models
1984 HOLDEN
CHRISDALY
  • 8 POSTS
If air enters the manifold under carby mounting flange what will happen?
If a float level is set higher than manufactures recommendations what will this cause?
Feb 13, 2010 at 3:31 PM
PGRTRUCK
  • 21 POSTS
If air enters under the carb the engine will run lean er and idle speed will be hard to maintane. Setting the float higher than specs can result in flooding and running to rich.
Regards
Peter
Sep 4, 2010 at 12:19 PM
