2002 Holden Commodore BATTERY LIGHT IS ON
12,900 MILES • 6 CYL • 2WD • AUTOMATIC
VX2002
I REPLACED ALTERNATOR 15,000 km AGO BUT NOW HAVE BATTERY LIGHT ON. IT SHOULDN'T BE ALTERNATOR AS IT HAS DONE NEXT TO NO WORK. I TRIED A NEW REGULATOR BUT IT DID NOTHING WHAT ELSE COULD IT BE
Jul 10, 2009 at 2:11 PM
  • 31,937 POSTS
Hi there,
It is a mistake to presume anything with motor cars, check the alternator out put first, report back your findings.
mark (mhpautos)
Jul 10, 2009 at 10:23 PM
VX2002
I tested the battery it is showing 11.5 volts with the engine off. With the engine running there are 12.8 volts. I also checked at the back of the alternator it produced the same readings.
Jul 12, 2009 at 5:55 PM
  • 31,937 POSTS
Hi there,
The alternator out put is way to low for that battery charge, i would be having it inspected by a auto elect, and get the battery load tested as well,
mark (mhpautos)
Jul 12, 2009 at 6:06 PM
