2001 Holden Commodore hairline fractures
NACKERS0000
  • 2001 HOLDEN COMMODORE
Engine Mechanical problem
2001 Holden Commodore V8 Two Wheel Drive Automatic
how serious are hairline fractures?
Sunday, October 25th, 2009 AT 7:09 AM
  • 31,937 POSTS
Hi there,
If you are referring to cylinder heads, this is not a huge problem as they can be ground out and welded up, there are occasions that they are not able to chase them all the way then this is a bit more of a problem, but under normal conditions a pressure check and a dye penetration crack test will prove the repair successful.
Mark (mhpautos)
Sunday, October 25th, 2009 AT 7:58 AM
