1999 Holden Commodore Warning lights
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVID CURLEY
Most warning lights are coming on and staying on. Engine will not turn over
Nov 4, 2010 at 1:33 PM
  • 31,937 POSTS
when you say it will not turn over, you mean no key cranking?
mark (mhpautos)
Nov 8, 2010 at 5:23 PM
DAVID CURLEY
Sometimes nothing when key turned, other times just turns and fires but will not run. Sometimes starts and runs perfectly with no warning lights coming up, Has now no headlights, Taillights or brake lights. Please help
Nov 9, 2010 at 8:18 PM
  • 31,937 POSTS
Check all power through the fuses with a multimeter, and run a diagnostic code check, a crank angle sensor is a common no start fault, but this will not affect the headlights, i would be concentrating on getting it running first.
mark (mhpautos)
Nov 10, 2010 at 7:26 AM
