1999 Holden Commodore car lights wont turn off
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
NICHOLAS289
hey guys
would be able to help me i have a holden commordore i woke up in the morning with a flat battery. so i looked to find out if something was lefted on.. but nothing was so i put a new battery in it. and the low beam was still on. so i just pulled a fuse out on the r/h/f fuse box.. is there anything i can do? i went to get new fuse.. but it has the lights still on... i have to take it out each night so the battery wont go flat. but have trouble starting it with out it... if you guys could help
Nov 5, 2009 at 6:55 AM
  • 31,937 POSTS
Hi there check the relay next to the battery and if that is ok, (just swap with a same type to test) i feel it will be the switch.
Mark (mhpautos)
Nov 5, 2009 at 7:24 AM
NICHOLAS289
hey guys well i cant find cause its got ingition fuse and relaqy wat do i look 4?
cause i only new to holden wel to that anyway... how do i change the switch or do i take it to a auto elec...
Nov 5, 2009 at 8:23 AM
  • 31,937 POSTS
Hi there, if your not sure get an auto lec to check the relay and the switch.
Mark (mhpautos)
Nov 5, 2009 at 2:09 PM
