1997 Holden Commodore loud squealing
19,000 MILES • 6 CYL • 2WD • AUTOMATIC
WALLI2000
I have a squeeky noise coming from the belt. i have replaced the belt two months ago, and most of the bearings are new as well, the others are running freely. I have also replaced the tensioner. When I spray a tiny amount of water on the belt it goes away for about 5 seconds. Could it be that the bottom crank pully is too smooth?
Please help, Craig
Aug 19, 2009 at 3:33 PM
  • 31,937 POSTS
Hi there,
There are problems with pulley alignment on some V6 commodores, some work shops now have Lazar aligners to check for this problem, tell tale signs are scuffing on the edge or the serpentine belt, also any oil or grease on a pulley will cause a noise sometimes.
mark (mhpautos)
Aug 19, 2009 at 4:17 PM
