1997 Holden Commodore engine misfiring under load
CROM93
Engine Performance problem
1997 Holden Commodore 6 cyl Two Wheel Drive Automatic 200.00 miles
hey i have just recently serviced my commodore and put injecter flush in tank . after washing the engine down i noticed on the test drive it was misffiring and backfiring mainly underload . i replaced the spark plugs and leads checked fuel injectors ok . ckecked blocked catalyc converter ok , found runing pretty much th same wen disconected the no and no sparkplug leads im thinking it may be crank angle scencor or coils wat do u think and how would i go about confirming problem with coil
cheers
Mar 25, 2009 at 12:25 AM
SCOTTIE666
Crom93,
mine is doing the same thing bud, and i have done the exact things you have done. i have asked around and nobody can seem to give me answer. i'm maybe thinking something internal. i will let you know if i get an answer. i have posted questions on just commodores so hopefully i will get an answer soon.
talk laterr
scott
Apr 3, 2009 at 11:09 PM
BADVK84
well i had an identical problem in my VR Calais under load it would miss badly and got to the extent where i couldn't drive it. the problem was the check valve in the fuel pump not allowing the fuel pressure underload. i suggest not getting a "fuelmiser" brand pump from autopro you are better off to get a bosch or get a genuine pump from holden.
Apr 21, 2009 at 8:14 PM
