1997 Holden Commodore crank angle sensor
186,000 MILES • 6 CYL • 2WD • AUTOMATIC
SULL85
my car sometimes has trouble starting and stalls while driving i think it might be the crank angle sensor but dont know how to check if it is buggered
Jan 26, 2009 at 6:36 PM
  • 31,937 POSTS
Hi there.
You won't be able to test it easily if it is an intermittent fault, chances are it will show as good, but as this is a common problem just replace it and i feel that your problems will be solved.
Mark (mhpautos)
Jan 26, 2009 at 7:44 PM
