1996 Holden Commodore fan belt
1996 HOLDEN COMMODORE
FEASTY
Engine Mechanical problem
1996 Holden Commodore 6 cyl Two Wheel Drive Automatic
how to know when to replace fan belt
Mar 14, 2010 at 12:53 PM
BLACKOP555
  • 10,386 POSTS
check the belt for cracks going with the ridges in it and if you can see the cords its bad. also check for glazing should be some what plyable and not hard as plastic. if it is replace. now looking at the auto tensioner there will be a range marks on the tensioner housing and the mark should be within the range marks. if not the belt is too stretched.
Mar 15, 2010 at 2:39 AM
