1995 Holden Commodore over heating.
PATEL.TEJASH
Heater problem
1995 Holden Commodore 6 cyl Two Wheel Drive Automatic
hi,
i have holden commodre. and i got heating problem in there. most probably in summer.my cooling fans are working. and i am doing service regularly...
could you please tell me what i need to do.?
Mar 19, 2010 at 11:19 PM
  • 31,937 POSTS
Hi there,
First check that the thermostat is OK, and get the radiator cleaned & flow tested, check for any external leaks and make sure that the pressure cap is holding the correct pressure, if this is all OK, you will have to get a Co head check done for a head gasket problem, is you car on LPG?
mark (mhpautos)
Mar 20, 2010 at 12:55 AM
