1995 Holden Commodore
MAX7
  • 1995 HOLDEN COMMODORE
1995 Holden Commodore 6 cyl All Wheel Drive Automatic
I have a VS series one, the car will run but only for a short period of time, as soon as it is turned on the battery light switches on, after a short distance the Engine light and ABS light turn on, the car will continue to stay on but it loses its responsivness. What could it be?
Sunday, July 26th, 2009 AT 11:01 PM
  • 31,937 POSTS
Hi there,
Start with checking the alternator charge rate.
Mark (mhpautos)
Sunday, July 26th, 2009 AT 11:28 PM
MAX7
Ok done that, also charged the battery, changed the leads, plugs and coil pack and still no change.
Monday, July 27th, 2009 AT 5:17 AM
  • 31,937 POSTS
Hi there,
Did you do a code read, do this and report the codes here, that way we will have some idea as to what we are looking at.
Mark (mhpautos)
Monday, July 27th, 2009 AT 6:04 AM
MAX7
Ok cheers for that, im a plumber not a mechanic do I need to get it to a mechanic/autoelec for a code read?
Monday, July 27th, 2009 AT 6:15 AM
  • 31,937 POSTS
HI there,
You can do this your self, I will find the pin codes and post the procedure here.
Mark (mhpautos)
Monday, July 27th, 2009 AT 6:21 AM
MAX7
Thanx for all your help, ended up taking to a mechanic turns out it was the alternator capacitor
Thursday, July 30th, 2009 AT 3:58 AM
