1994 Holden Commodore the car does not want to change gear
1994 HOLDEN COMMODORE
900 MILES • 6 CYL • 2WD • AUTOMATIC
KIKI ADJIE
my car doesnt want to change its gear.... the alternator is damage .. each time when I repair the alternator, it will run normaly and the gears will work properly, but only for a few kilometers, suddenly the gear doesnt want to change again...when I turn off the car, and I start the engine again , the indicator engine light will not turn off. and the alternator is broken again .
Apr 26, 2009 at 6:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
If something is burning out the alternator then you need to start with inspecting the battery terminals and cables. If the terminals are corroded or cables damaged it will cause damage to alternator.
Thanks for using 2CarPros.com!
Apr 27, 2009 at 11:03 AM
