1994 Holden Commodore NEED HELP
SAMNTHA
  • 6 POSTS
Engine Mechanical problem
1994 Holden Commodore 6 cyl Automatic
Hi, i have a vr commodore 1994, ive been having problems with the running of my car, i seems like its choking when im driving it now starting to backfire.. i took the car to a mechanic and he put it on a computer and told me i have to replace the car computer which i did and it didnt fix the problem, took the car to an auto elec and he found nothing wrong with the wiring, since then i have replaced crank angle sensor, fuel pump and filter, coil and modular , spark plug leads and spark plugs... and its still doing the same thing , has anyone got any ideas for me to fix this car.. thankyou
Oct 26, 2008 at 9:08 PM
  • 31,937 POSTS
Hi there,
I would be checking the air flow meter and the throttle position sensor. also check for a cracked or broken vacuum line at the base of the throttle body.
Run a scan and check for any set fault codes, as the check light will not always come on with a fault, also check that the earth wire at the base of the coil pack is tight and clean. start here.
mark (mhpautos)
Oct 26, 2008 at 10:08 PM
SAMNTHA
  • 6 POSTS
WHERE IS THE AIR FLOW METER ONA VR COMMODRE 1994 MODEL .. THANKYOU
Oct 26, 2008 at 10:14 PM
  • 31,937 POSTS
Sorry, i meant to say MAP sensor not airflow.
Mark (mhpautos)
Oct 27, 2008 at 4:23 PM
SAMNTHA
  • 6 POSTS
Hi , i have changed the MAP Sensor and its still the same, thankyou
Oct 27, 2008 at 4:33 PM
  • 31,937 POSTS
Have you re scanned for fault codes? and dose your mechanic have a scanner that gives life data, this will help pin point the fault.
Mark (mhpautos)
Oct 27, 2008 at 4:39 PM
  • 31,937 POSTS
Have you checked the coolant temp sensor for correct readings?
Mark
Oct 27, 2008 at 4:41 PM
SAMNTHA
  • 6 POSTS
i have the car booked into Mantello Holden tomorrow to do another test on the car
Oct 27, 2008 at 4:42 PM
  • 31,937 POSTS
Ok, let me know how you get on.
Mark
Oct 27, 2008 at 4:46 PM
SAMNTHA
  • 6 POSTS
i will , thankyou
Oct 27, 2008 at 4:48 PM
SAMNTHA
  • 6 POSTS
Commodore is finally fixed and back on the road... thanks for everyones help ..
Oct 30, 2008 at 4:57 PM
