1993 Holden Commodore heater controls
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLACKADDDER
the heater only blows hot air from the foot vents
May 26, 2010 at 7:40 PM
  • 31,937 POSTS
Hi there,
This is usually a vacuum leak in the bi level controls, this is in behind the lower dash and is a real pain to get to, what you will have to be very careful of is that if you are not very careful you may disconnect other vacuum hoses and then it is a real pain to sort them out, best get your local mechanic to check this out for you.
mark (mhpautos)
May 26, 2010 at 7:52 PM
