1987 Holden Commodore vl commodore
STEVEYLOL
Electrical problem
1987 Holden Commodore 6 cyl Two Wheel Drive Automatic
the car will run when its cold but once it heats up it will not started agane un till its cold is there any thing i can do to fix it
Oct 1, 2009 at 1:17 PM
  • 31,937 POSTS
Hi there,
Have the crank angle sensor checked as this is often the problem with this type of issue, there should be a set fault code in the ECU that will pin point this if it is the fault.
Mark (mhpautos)
Oct 7, 2009 at 9:58 AM
