1988 Holden Camira Cooling Fan not working
1988 HOLDEN CAMIRA
262,500 MILES • 4 CYL • FWD • AUTOMATIC
GEOFF59
It appears that my cooling fan is not working. I have replaced the temperature sensor unit and checked the relay. When I connect the cooling fan wires directly to the battery it runs OK. I had a fault code 14 which indicates low voltage. I reset the diagnostic code and ran the engine for 60 seconds as recommened by my workshop manual and checked the code and it was 12 = OK. I also checked the voltage between the sensor terminals and it was 5 volts which is betwen the recommened 4-6 volts. The only thing I have not checked is for continuity between the sensor connector and the C10 on the control unit. Normally when I switch on the air conditioning compressor and switch on the ignition or run the engine the cooling fan runs, but now it does not. Also when shorting A/B on the diagnostic unit and I switch on the ignition the cooling fan should run but it does not. On my JD it does run. I have also swapped the relay and no difference.
Mar 12, 2010 at 6:13 PM
MMPRINCE4000
  • 8,548 POSTS
You are going to have to check the wiring in the fan circuit, you may have an open wire due to frayed insultion, or heat stress.
Mar 15, 2010 at 1:40 AM
