1985 Holden Camira drive shaft
1985 HOLDEN CAMIRA
TIM_TIM15
Drive Train Axles Bearings problem
1985 Holden Camira 4 cyl Automatic
how do i remove the drive shaft from the gearbox because we are putting in a nw gearbox?
Aug 9, 2009 at 4:34 PM
  • 31,937 POSTS
Hi there,
Remove front wheels, undo drive shaft end nut, drop off tie rod end and lower ball joint swing steering hub out to extract drive shaft spline, drive shaft id held in transmission by an internal "C'clip which will relaeas when you carefully lever out the drive shaft, it should pop out quite easily, just drain the transmission of oil first.
mark (mhpautos)
Aug 9, 2009 at 5:27 PM
