1995 Holden Barina Check Engine Light
1995 HOLDEN BARINA
NICHOLKA
Computer problem
1995 Holden Barina 4 cyl Front Wheel Drive Manual
Hi There, While driving the check engine lights pops on for a few seconds and then goes again. I have had a look in the manual and it says that i will need to get my computer management system looked at. Can you advise what could be making the light come on? I can still drive my car and everything else is fine.
Nov 16, 2008 at 10:57 AM
  • 31,937 POSTS
Hi there,
There are many reasons that can cause the check light to come on, there will be a fault code stored in the memory of the ECU, a scan will retrieve this code and will identify the problem area.
mark (mhpautos)
Nov 16, 2008 at 9:53 PM
