Hold light and gear problem
1,400,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RASOOL_92
Hold light blinks and the gear shift from the first gear to the third with out passing the second gear and never shifts to fourth gear. Any suggestions? Thanks.
Aug 9, 2018 at 2:26 AM
  • 55,647 POSTS
This sounds like you have a clogged catalytic converter which will change the vacuum reading if the engine causing the transmission not to shift to confirm the issue please go over this guide.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Cheers, Ken
Aug 10, 2018 at 5:57 AM
