Hit bump and my truck immediately shut off and will not start?
2008 TOYOTA TACOMA
45,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
WMBLAKENEY73
It will crank but not start. Replaced fuel pump and still won't start.
Nov 3, 2022 at 4:43 AM
  • 110,244 POSTS
If the starter is working, try this and let me know the results. See if it will start for a couple of seconds using starting fluid. If it does and then stalls, we know it is fuel related. If there is no change, then it is likely ignition related. In that case, check to see if there is spark to the plugs. Here is a link that explains how that is done. This will help narrow things down for me, so I know which circuits to focus on.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Also, let me know how bad the bump was, if anything under the vehicle hit, or anything you can think of that may help.
Nov 3, 2022 at 7:00 AM
