Hit a curb now front left wheel is further back than it should be
20,000 MILES
CARLOSK
I slid into a curb going 5-10 MPH on a right turn because of icy roads. My front left tire hit the curb and now it’s further back than it should be. What should I do? Which parts might be the issue? Thank you
Mar 17, 2022 at 12:37 AM
SQM
  • 6,383 POSTS
Depending on how much it bent, you might need a few suspension components.
If it is minor, then it is possible that all you will need is an alignment.
The best course of action would be to inspect the vehicle and look for any broken or damaged components. Especially the control arms and possibly the spindle.
Is this vehicle drivable?
If you can take it to an alignment shop for alignment, they will be able to tell you if just an alignment will fix the issue.
Mar 17, 2022 at 6:15 AM
