Hissing sound from air conditioner unit
2013 PROTON
7,700 MILES • 1.3L • 4 CYL • FWD • AUTOMATIC
DRAMIRUL93
When turn on the a/c, there will be hissing sound comes from inside dashboard every 1 minute interval, and the air blown somehow not cool as usual.
Another problem is water drop (under bonnet) comes out from a/c system also quite often/a lot compare to normal car air conditional unit.
Compressor sound from engine also quite often, it is synchronized with the hissing sound comes from dashboard.
Is there any problem with cooling coil or thermal expansion valve?
Could you suggest me
Feb 7, 2015 at 12:36 AM
KHLOW2008
  • 41,812 POSTS
Have the high and low pressure checked and let us know the actual reading.
Feb 12, 2015 at 10:12 PM
  • 55,682 POSTS
To me it sounds like you have a evaporator drain tube that is clogged, here is ahow to find it and unclog it in this vide.
https://youtu.be/q9_MZiS2_NE?si=wdUi_rDAIgP5WA3S
Please go over this guide and get back to us.
Jul 17, 2024 at 10:58 AM
