Hissing noise along with rough idle
224,645 MILES • 4 CYL • FWD • AUTOMATIC
AMBER DUKE WHELDEN
  • 6 POSTS
For the past five months or so it has had a really bad idle. It idles at almost 0 rpm's. Along with the low idle it has a really bad sputter, and has trouble when taking off from a stop (I am thinking a misfire). I have been driving it like that for nearly five months, as no one can pin point the problem, and I have replaced many things already. Nothings seemed to change it. Just today it started making a hissing nose under the engine, sounds almost like air being brought in. Any idea what this could be, and if they are related?
Aug 16, 2016 at 5:55 AM
SATURNTECH9
  • 30,868 POSTS
The noise sounds like a vacuum leak which can effect the engine running cause a miss etc.Has anyone ever done a smoke test looking for a vacuum leak?
Aug 16, 2016 at 9:51 AM
AMBER DUKE WHELDEN
  • 6 POSTS
The transmission just totally went, after barely making it home. Not sure if it was related to the noises, but now it is a much worse problem.
Aug 16, 2016 at 11:03 AM
SATURNTECH9
  • 30,868 POSTS
That is terrible did it just stop moving ?
Aug 16, 2016 at 1:17 PM
