higher than normal idle?
1999 CHEVROLET S-10
120,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
SCRILLA0423
My truck runs fine, then sometimes when the clutch is pressed it idles about 200 RPMs higher than normal and pretty much stays there until i shut off the vehicle or rev up the engine to about 5,000 RPMs.
Sep 8, 2022 at 2:30 AM
  • 110,244 POSTS
Idle speed is controlled by the idle air control valve. This is located on the throttle body and can get dirty and possibly hang up enough to change the idle speed.
If you look at the pic below, it shows the IAC. What I suggest is this. First, service the IAC valve. Make sure there are no carbon deposits in the throttle body where it mounts.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/idle-air-control-valve-service
Next, it is wise to also clean the throttle actuator bore. Do this in addition and it should take care of the issue.
Let me know if that helps or if you have other questions.
Sep 8, 2022 at 1:28 PM
SCRILLA0423
Thank you, guys, will get on it ASAP.
Sep 9, 2022 at 2:50 AM
