My van has high idle when starting up the van. But the coil pack is new and had to put new coil connector plug in and with wires. Speedometer and tachometer reading does not work and I have to hit the dashboard to get it all working again. Some say PCM relay or computer itself. I did new spark plugs and wires and all is replaced. I am going to try new EGR valve TMW. Hope it solves all. I did have a code before for a mass air flow sensor but not now . Any thoughts about fuses or anything? EGR valve replaced still rpm too high over like 2,000. No check engine light. New camshaft sensor and new crankshaft sensor. Idle air control sensor or valve?
Jul 10, 2018 at 4:13 AM
