car has a hard time accelerating up hills ?
1,999,987 MILES • V6 • 2WD • AUTOMATIC
HSE JODY RAE
The car has a hard time accelerating up hills and the RPMs are almost going to the red. i hooked up a diagnostic and it kept reading linking error, then misfire on #4.
Mar 15, 2023 at 2:29 AM
  • 55,616 POSTS
The first thing I would do is check the transmission fluid.
Here is a guide to help:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Also, you should do a normal tune up by replacing the spark plugs and fuel filter. I would also clean the throttle body as well.
These guides can help walk you through the repairs:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
and
Please go over these guides and report back.
Mar 15, 2023 at 9:50 AM
