High rev, slow on uphill and weak, oil light on
395,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
ABDUL TOUFFIE
My vehicle is very very weak on the uphill and generally on pull away one has to rev high in 1 gear there after it's just slow. I am scared I might blow the head. The oil light keeps on coming up on my dash.. Only when I stop goes away when I rev the car...
Also the car tend to switch off when I get to a stop... Then after a few swing she starts again...
4 months ago I had an engine overhaul done and now I have leaks that comes from the cylinder head...
Yet there is good pressure coming from the spark plugs I have tested... All seemed to be order... But I did not change the oil pump and I cannot find the fuel pump.
Please advise.
Apr 17, 2021 at 9:47 PM
Let's start with a couple things you mentioned. First, when you say you checked the pressure, was this a compression test?
If so, what were the readings?
Next the oil light coming on unless you are revving the engine is a sign of low pressure and the pump is most likely the issue.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
However, this most likely will not cause the low power issue that you are seeing. Here is a guide that will help with this:
What I am concerned about is that the motor is starting to lock up due to low oil pressure. So the first thing we need to do is change the oil and drain all the old oil through a coffee filter so that you can inspect for oil. You will want to capture the oil in a clean pan and then start pouring it slowly through a filter so that you can see how much oil is there, or let the oil settle in a pan and then pour off the oil slowly so you can see what is at the bottom of the pan.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Let us know what you find with this and we can go from there. Thanks
Apr 18, 2021 at 12:34 AM
ABDUL TOUFFIE
Thank you I will inform the group on how it went... I need to do he compression test on all valves again
As for the oil I will drain it and keep an eye on the sludge once drained... Now in the gasket cover where is this oil filter thingy... I got to have a look at it but how do I find it....
Anyway I will follow these instructions as describe and will get back to you
Thank you once again.
Apr 18, 2021 at 2:14 AM
NICKOLAOSF
  • 69 POSTS
Hi ABDUL TOUFFIE
we can help with your issues, first we will start from the begging, and move forward, check engine oil level report back if ok, if not adjust to manufacture level, second scan for any stored codes (see link)
Let us know what happens and please upload pictures or videos of the problem. let us know if engine was removed for repair and take a picture of the leak area showing. Please run down these guides and report back. Cheers Nick
Apr 18, 2021 at 3:25 AM
