How to remove the High-Pressure Fuel Pump connector?
140,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
FARMERW
I am unfamiliar with this type of connector. How do I release it to remove? I don't want to break it. See attached picture. It has a blue ear on the visible side.
It is only a 2-pin connector.
Apr 9, 2024 at 7:51 AM
  • 110,251 POSTS
The blue tab is a safety to prevent it from coming off. It should slide out from the connector and then you should be able to depress the release and remove the connector.
Apr 9, 2024 at 12:39 PM
FARMERW
thanks. The connector was quite brittle. Blue part broke but was able to maintain the key locking feature for re-installing. Thanks.
Apr 9, 2024 at 2:39 PM
  • 110,251 POSTS
You are very welcome. As far as the connector is concerned, the heat causes them to get that way. If it didn't fall apart, you did good!!! LOL
Take care of yourself and feel free to come back anytime in the future.
Apr 10, 2024 at 11:02 AM
