High pitched whining when starting
119,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
JAMES PELFREY
I replaced the head gaskets and all the gaskets above and when i start it it has a high pitched whining noise. I replaced all the idler pulleys the water pump and the tensioner and had the alternator check but its still doing it.
Mar 14, 2021 at 6:15 AM
Good afternoon,
Please upload a video of the noise for us to hear.
https://www.2carpros.com/articles/car-squeaking-noise
Double check the belt routing and alignment for the noise.
Also, check the power steering fluid to be sure it is not low. It will cause a noise as well.
https://www.2carpros.com/articles/power-steering-fluid-flush
Mar 14, 2021 at 8:16 AM
