After the engine has been running for thirty to forty minutes it idles rough and high MPG
109,500 MILES • 3.5L • 6 CYL
ROSI
After replacing all four oxygen sensors and MAF sensor problem still persist. Subaru dealership told me that the engine has low compression in 140-150 PSI range in all six cylinders and I need to replace engine.The car runs just fine. I do not understand how is this possible. I am devastated. Please advise.
Jul 12, 2018 at 4:28 PM
STEVE W.
  • 15,402 POSTS
Well those numbers are a bit low, that engine should be in the 180-220 psi range. However, it sounds more like it may simply need to have the head gaskets replaced, Subaru engines all seem to have gasket failures. I would do a leak down test to see if the engine is leaking past the rings or valves first. This lists a few tests that can be done, by you or most shops (you do not have to use a dealer) to see if this could be the problem. Then see what the pricing would be for the repair. Shop around a bit if you do not want to DIY the repairs.
Jul 12, 2018 at 7:15 PM
