High low beam turn signal mechanism
103,000 MILES
JUDY COLEMAN RIEDEL
Can not get high low beam selection arm to do the exchange. Signals work. Feels as if signal has lost housing piece which regulates arm to select high beam.
Jan 8, 2017 at 12:21 PM
HMAC300
  • 48,601 POSTS
that means you will probably have to replace the multi function switch. unless you can get steering wheel off and see if you can find the problem, but it may be just worn out.
Jan 8, 2017 at 10:53 PM
