Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Frontier
Engine
Symptoms
Idle High
High idle when transmission put into gear
2000 NISSAN FRONTIER
150,000 MILES • 3.3L • 6 CYL • 2WD • MANUAL
GLYNB356
MEMBER
Tachometer/engine runs up to 2000 rpm's when I put it in gear. Prior to being in gear has normal curb idle. What is up?
May 4, 2018 at 9:46 AM
Experienced Mechanic
It sounds like a TPS sensor could be out but to be sure lets run the codes to see what comes up.
Cheers, Ken
May 6, 2018 at 9:55 AM
GLYNB356
MEMBER
Replaced that already, This is happening when the shifter is put into gear. Educated guess it is a sensor on the gearbox. Really a question of is it?
May 6, 2018 at 12:03 PM
I do not think it has anything to do with the transmission. Is the check engine light on? Can we run the codes to see what comes up?
May 7, 2018 at 4:23 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
