High idle then low idle then die
CSHAPLEY
The truck will high idle then idle low then die when I try to give it gas. Its also running rough. Am thinking it might be my full injectors or throttle body. I really don't wanna replace these until am sure that's the problem
Sep 9, 2013 at 10:15 PM
HMAC300
  • 48,601 POSTS
spray choke cleaner at the base of the tbi unit as the gasket may be blown. if rpm changes or smooths out it is. check fuel pressure as well.and scan for codes.
Sep 9, 2013 at 10:44 PM
CSHAPLEY
I also took off the blower on top and turned it over ans flames came out the carb/ fuel injector
Sep 9, 2013 at 11:05 PM
HMAC300
  • 48,601 POSTS
just do what I said in the reply you don't have a blower on your truck
Sep 9, 2013 at 11:17 PM
