High idle speed, codes p0123, p0122, p0113
1,700,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
LARRY NASON
  • 48 POSTS
Hello again. I was hoping you would be able to tell me how adjust a throttle position sensor.
So I put an obd2 scanner on the car and I got three codes the first one being p0123 it says throttle pedal position sensor switch a circuit high. The second code is p0122 and it says throttle pedal position sensor switch a circuit low. The third and final code reads p0113 and it reads intake air temperature sensor 1 circuit high. Can you tell me what would cause these codes please?
Feb 25, 2019 at 11:46 PM
LARRY NASON
  • 48 POSTS
I don't know if this helps at all. but there's this too:
Feb 26, 2019 at 2:49 AM
  • 55,746 POSTS
I have seen this problem before. either the sensor is bad throttle pedal sensor or the throttle actuator needs to be cleaned. here is a guide to help with the cleaning and the adjustment and replacement instructions are in the diagrams below:
Feb 27, 2019 at 3:22 AM
LARRY NASON
  • 48 POSTS
Thank you Ken for your help. I replaced the TPS and that fixed the idle and cleared all but one of the codes. Now I just have the air intake temperature sensor.
Feb 27, 2019 at 5:02 AM
  • 55,746 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Feb 28, 2019 at 1:52 AM
