High idle popping and back fire
145,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
A1HI
  • 31 POSTS
Replaced the spark plugs and rocker arm assembly cleaned mafs, to get to plugs had to remove air intake and coil on plugs. I started it had high idle then it would go down and fluctuate up and down some popping and backfire.When I installed rocker arm assembly I made sure engine was on tdc. What would be the best way to repair this problem.
May 2, 2015 at 3:29 AM
HMAC300
  • 48,601 POSTS
try driving it as the computer has to get used to new plugs if it doesn't straighten out then scan for codes and check fuel pressure with a gauge
May 3, 2015 at 9:24 AM
A1HI
  • 31 POSTS
I am getting codes
P2074 Dodge
P2074 Dodge - Manifold Pressure/Throttle Position Correlation- High Flow/Vacuum Leak
PDF Share Code
0 P2074 Dodge Comments | Add Comment
Possible causes
- Large vacuum leak on the engine
- Faulty Manifold Pressure (MAP) sensor
- Faulty Throttle Position Sensor (TPS)
- Faulty Engine Control Module (ECM)
P0064
P0064 - HO2S Heater Control Circuit High Bank 2 Sensor 3
PDF Share Code
0 P0064 Comments | Add Comment
Possible causes
- Faulty Heated Oxygen Sensor (H2OS) Bank 2 Sensor 3
- Heated Oxygen Sensor (H2OS) Bank 2 Sensor 3 harness is open shorted
- Heated Oxygen Sensor (H2OS) Bank 2 Sensor 3 circuit poor electrical connection
- Heated Oxygen Sensor (H2OS) Bank 2 Sensor 3 circuit fuse
Read more: http://engine-codes.com/p0064.html#ixzz3Z8K0GZ8j
May 3, 2015 at 12:32 PM
A1HI
  • 31 POSTS
I am getting voltage to mafs, removed and tested tps and idle air control thy tested good.
May 3, 2015 at 12:39 PM
HMAC300
  • 48,601 POSTS
if th parts tested good check for air leaks like the duct work leading to engine with holes in it or not sealed correctly to engine or after maf and check all grommets on engine causing an air leak as well. then use choke cleaner and spray around intake and hoses for a vacuum leak. lastly as you removed intake it may have destroyed a gasket causing your problem so check that.
May 3, 2015 at 11:46 PM
