Replaced the spark plugs and rocker arm assembly cleaned mafs, to get to plugs had to remove air intake and coil on plugs. I started it had high idle then it would go down and fluctuate up and down some popping and backfire.When I installed rocker arm assembly I made sure engine was on tdc. What would be the best way to repair this problem.
May 2, 2015 at 3:29 AM
