Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Silhouette
Engine
Symptoms
Idle High
High idle in park
2002 OLDSMOBILE SILHOUETTE
234,444 MILES • 2.4L • 6 CYL • 4WD • AUTOMATIC
EBILLINGS17
MEMBER
1 POST
We changed the idle air control valve. We did a oil change and plugs and wires replaced. Engine idling high in park. What could be the issue?
Aug 23, 2018 at 12:10 PM
Experienced Mechanic
Good morning.
Did you clean out the passages real good from all carbon when you replaced the IAC?
Are all the vacuum lines attached?? look for any loose or broken lines.
Throttle body having carbon deposits can also cause this as well. Clean it with a cleaner and a tooth brush to remove all the build up.
Is the check engine light on?
Aug 23, 2018 at 9:24 PM
Add image or video
Ask a new question
Engine won't start
Engine overheating
